Default 'save as' options
Hi team, I routinely save emails as PDF’s as they need to be uploaded into a system that only accepts that file type. It would be nice to avoid changing the file type from .eml each time.
I could see a number of solutions to this such as,
  • Simply creating an option in the settings to set the default ‘save as’ file type
  • Adding a sub menu to the ‘save as’ option in the jump list that gives you the option of either file type
  • Emclient could remember the previously used file type, as it already does with the save path
Cheers!
