I have too many duplicates to set/check manually, which to keep which to remove?
Any chance to say that to keep them e.g. in Inbox and delete Inbox/eM Client Forum
thank you
stefan
thank you
stefan
Same applies to Contacts. It would be ideal to select which folder to use. I guess a workaround would be to move them to a temporary folder then move them all to the desired folder but that is rather clunky.
