Can you deactivate eM Client for me so I can activate it?
Thank You,
DAVE, YOU CAN ACTIVATE OR DEACTIVATE EASILY. GO TO EMAIL CLIENT, OPEN SETTINGS, GO TO HELP, GO TO LICENSE. HOPE THIS HELPS!
I don’t have deactivate on my version I’m running version 7.0.27943.0
and when I try to activate it it say it needs to be deactivated first
Thank You, Bode717
Hello Dave,
I see that you have the same license activated on 2 different devices.
I deactivated both, please use the license key to activate only one device.
That might be my problem too although I don’t recall getting a license. Any chance you could deactivate mine too so that I can start over?
I know what you mean, I had to uninstall mine then download it again. Then I was able to insert my license key, now all works fine.
Dave - I am glad the issue is resolved for you.
Kathleen - I cannot find any license under your mail address, can you contact me from the mail address under which you registered a license so I can manage your activations? You can contacts me at [email protected]
