Is it possible to batch remove duplicate emails and contacts? Upon importing from Outlook, I’ve got duplicated emails and contacts, which I’d like to “de-duplicate”.
George
Problem solved:
Apparently in Outlook there were two identical “Personal Folders” loaded, even though they corresponded to only one outlook pst file. That’s why eM doubled the emails and contacts.
Hello.
No, unfortunately there isn’t such possibility.
Why are your data duplicated after import? How did you import your data?
Milos Kovalcik.
How did you close the other “Personal” folder in Outlook before you imported?
