DBRepair stopped working
Try repairing the install.Start Program Files find emclient right click select repair
then reboot
Also look at reinstalling .NET Framework, as system.transactions.dll is a component of that.
Richard: The system can’t find setup(2)msi so the repair won’t run.
You can download and install the latest version from http://www.emclient.com/release-history. If this is the same version you have installed, you will be prompted to perform a repair.
Gary: Got it!
Gary: The install didn’t ask for a repair. It just installed the whole thing…
If it did not offer a repair, that means it is probably a newer version.
See how that goes.
I went to Programs and Features and tried a repair, and the repair was ok. Tried to run eM Client again, but got the same result. Tried a repair of .NET Framework and that failed.
Did you restart the computer?
