Hi. Just upgraded to latest version. Is there a way to tighten up the line spacing between folders in the left column? I’d like to be able see more of my folders the way I could in 7.2 versions. I see how you can tighten things up in Settings for the 2nd column but not the first. Help!!! And thank you!
The option is in Menu > Settings > Appearance > Lists.
You can also click on a folder, and while holding the Ctrl key, scroll the mouse wheel over the folders.
Yes, I adjusted that down to the lowest it would allow which is 18 pixels. I guess it won’t tighten up any further than that so I’ll just have to get used to it.
Thank you, Gary.
