Customise shortcut that's not in list
Hi…
I wanted to customise the permanent delete shortcut - shift+del - to alt+k to match a previous client but ti doesn’t seem to be in the shortcuts list - or I have gone blind! Any thoughts?
martes 25 enero 2022 :: 0827hrs (UTC +01:00)
Sí, tengo pensamientos, uno en particular: ¿por qué necesita un atajo para eliminar?
¡Simplemente presione la tecla Eliminar en su teclado!
¡Saludos desde la soleada Sevilla España!
Skybat
Shift delete exists to permanently delete messages, bypassing deleted items folder, and is part of emclient. I find it an essential function as I’m sure many others do. It’s just that it seems not to be in the list in settings.
Because Shift + Delete is a standard Windows shortcut, we use the same combination to permanently delete items bypassing the Trash.
Unfortunately we don’t offer an option to remap that shortcut. Sorry.
martes 25 enero 2022 :: 1115hrs (UTC +01:00)
Shift + Delete está disponible desde el sistema operativo, Windows y, más recientemente, MAC;
lo utilizan eMC y otros clientes de correo electrónico.
Esta será la razón por la cual no hay disponibilidad para editar la combinación de teclas dentro de eMC.
Skybat
