I’m trying to restore data that has been backed up on 4th Feb. I’ve downloaded the current version of emclient but at the end of the restore process I have the following error :
ICSharpCode.SharpZipLib.Zip.ZipException: CRC mismatch
à ICSharpCode.SharpZipLib.Zip.ZipInputStream.CompleteCloseEntry(Boolean testCrc)
à ICSharpCode.SharpZipLib.Zip.ZipInputStream.BodyRead(Byte[] buffer, Int32 offset, Int32 count)
à ICSharpCode.SharpZipLib.Zip.ZipInputStream.Read(Byte[] buffer, Int32 offset, Int32 count)
à ICSharpCode.SharpZipLib.Core.StreamUtils.Copy(Stream source, Stream destination, Byte[] buffer, ProgressHandler progressHandler, TimeSpan updateInterval, Object sender, String name, Int64 fixedTarget)
à DbBackup.FormBackup.Restore(String backupFile, CancellationToken cancellationToken)
à DbBackup.FormBackup.Restore(CancellationToken cancellationToken)
à DbBackup.FormBackup.<mainform_load>b__28_0(Object a, DoWorkEventArgs b)
à System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
à System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
Can anybody please help ?
info :
emclient v7.2.34666.0
Windows 10 64b
thanks
edit :
here is manifest of back up data file :
<?xml version="1.0" encoding="utf-8"?>
2019-02-04 21:07
eM Client
7.1.33101.0
MailClient
7.1.33101.0
777
</mainform_load>
