Crashes when copy and pasting. IE v11 is installed with the latest updates. I checked that the clipboard access setting (or whatever it is called) in IE security options was enabled, but that didn’t help.
EDIT: This is not happening on a specific email, but fairly often with a variety of different emails.
eM Client (6.0.23181.0)Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.42000
System.InvalidOperationException: Token EndElement in state TopLevel would result in an invalid XML document.
at System.Xml.XmlWellFormedWriter.ThrowInvalidStateTransition(Token token, State currentState)
at System.Xml.XmlWellFormedWriter.AdvanceState(Token token)
at System.Xml.XmlWellFormedWriter.WriteFullEndElement()
at MailClient.Utils.HtmlStyleWrapper.WriteShallowNode(XmlReader reader, XmlWriter writer)
at MailClient.Utils.HtmlStyleWrapper.ProcessHtml(TextReader input, TextWriter outputWriter, TextWriter styleWriter, String wrappingTag)
at MailClient.Utils.HtmlStyleWrapper.ProcessHtml(TextReader input, StringBuilder outputBuilder, StringBuilder styleBuilder, String wrappingTag)
at MailClient.Utils.Text.GetFilteredHtmlFromClipboard(String context, String& css)
at MailClient.UI.Forms.formSendMail.HtmlEditor_Paste(Object sender, PasteEventArgs e)
at Microsoft.ConsultingServices.HtmlEditor.HtmlEditorControl.TextPaste()
at MailClient.UI.Forms.formSendMail.pasteToolStripMenuItem_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at MailClient.Program.b__4() at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action`1 handler)
Hi Joshua,
could you please tell me which version of eM Client you’re running?
Also, does this happen when you copy and paste using the right-mouse button, when using shortcuts Ctrl+V and Ctrl+C or during both?
Hi Joshua,
sorry for the late reply. I see that you aren’t running the lates update. Have you tried updating to the latest release and see if the issue persists?
