Crash calendar month view despite fix v6.0.24928
Despite update-install latest fix v6.0.24928, I keep on getting below error msg while opening calendar:
get error msg eM Client (6.0.24144.0)
Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.42000
System.ArgumentOutOfRangeException: Year, Month, and Day parameters describe an un-representable DateTime.
   at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
etc.etc…
After reset system date to Feb.5th , calendar opens aslong as I don not use month view.
Seems fix v6.0.24928 does not fix this problem.
Issue solved,
source was that during first time installation I installed emclient in a different location as suggested by the system. Any updates afterwards are installed in the system suggested location.
