As far as I can tell em client crashes sending any email with attachments. I just installed EM, successfully sync’d my accounts, and can reliably cause this to happen. Any email with a jpg, and sometimes just trying to start the email, no attachments yet, and “eM Client has stopped working”. And then restarting you immediately go into “fixing corrupt database” which sounds real awful for your first experience (and this is why I was using this get off Outlook!). It seems to recover ok although it often says its hopelessly corrupt, but restarting again will let it start up. It also randomly crashes just making an email.
This client looks awesome but its completely unacceptable with the immediate crashes! What is wrong with you guys? Its look like a lot of work went into this yet its completely busted. Glad I did not pony up money yet. On to trial Thunderbird and I would have been completely happy with EM client – if it worked!
First check if you have the latest V10.4.5674 for Pc or Mac. If you don’t have it you can download and install it from the release history page. If you do update “close eM Client before installing”.
If you already have that version, then check you have the latest Win 10/11 OS updates or latest Mac OS update as there have been a lot recently.
If your OS is already up to date then crashes opening eM Client or when sending attachments can sometimes be caused by eg: optionally installed Firewall / Security programs or optionally installed Antivirus programs, vpns etc.
So if you have anything like that installed “other then what comes default with your OS, try completely disabling those to test incase of interference. Apart from that you might just need to try uninstall and reinstall & see if that fixes it.
If you do try uninstalling and reinstalling eM Client and have Windows “don’t delete the database” when asked on the uninstall wizard so it keeps your existing database intact.
Apart from that if you’re happy to test the new eM Client V11 Beta you could also optionally d/l & upgrade to that via the release history page and see if that makes any difference for this issue.
If you have already tried the latest V11.0.282 Beta from the Release History | eM Client and have nothing optionally installed running resident like I mentioned in my previous post above and you already have the latest OS updates for Win 10/11 or Mac, then as it’s still not resolved, suggest you email the Beta team if you haven’t already as they might need to check your profile or other logs to determine why it’s crashing.Problems with V11 Beta email [email protected]
