Could not connect to gmail
7:58:32 AM vr*****@gmail.com [IMAP] MailExceptions.ConnectionException: Failed opening connection to server. —> System.Net.Sockets.SocketException: The requested name is valid, but no data of the requested type was found
7:58:32 AM at System.Net.Sockets.TcpClient…ctor(String hostname, Int32 port)
7:58:32 AM at MailClient.Imap.Base.Connection.<>c__DisplayClassa.b__9()
7:58:32 AM at MailClient.Imap.Base.Connection.Connect(Func`1 getStream)
7:58:32 AM at MailClient.Imap.Base.Connection.Connect(String receiveHost, Int32 receivePort, Boolean explicitSsl)
7:58:32 AM at MailClient.Imap.ConnectionPoolEntry.Reconnect()
7:58:32 AM — End of inner exception stack trace —
I will need your IMAP logs, go to tools - settings - advanced, check IMAP under your account, apply and restart eM Client.
Simulate steps that leads to your issue and after that send logs… to [email protected] together with this topic’s URL in subject.
regards
Jan
