Copy and paste calendar events not working on mac
It is NOT available through the context menu right-click
i can not use ⌘ + C and ⌘ + V on Mac
version Version: 9.2.2144 (ad62e4c)
mac os sonoma 14.0
The Command ⌘ & C and Command ⌘ & V normally do work when copying & pasting calendar events unless you have maybe eg: switched those keys via the Mac System Settings “Modifyer Keys” as some users do, or there might be possibly a bug in that 9.2.2144 version.
Try then clicking on the Calendar event and then click “Edit / Copy” (in the menu) at the top.
Then click in the Calendar event where you want it to go and click “Edit / Paste” (in the menu).
If that still doesn’t work via the menu along the top, then there could be a bug and you might then have to wait for the next official eM Client for Mac update via the release history page.
Also try updating your Sonoma to 14.2 as i see you have 14.0 to see if that makes any difference.
thats it! i use a windows keyboard with my mac and have mapped the keys via the Mac System Settings “Modifyer Keys”
and the use the menu works fine
i fixed it by going to System Preferences > Keyboard > Keyboard Shortcuts > App Shortcuts >
and then i added shortcuts for
Cut ⌘ & X
Copy ⌘ & C
Paste ⌘ & V
and its all good
