Control + zero STILL does not work
When reading mail I can enlarge the display size with control + plus and reduce it with control + -, but control + zero does nothing.
I posted about this a year ago and someone on your side basically said “it works for me”, and that was the last I heard about it.
Well, it still doesn’t work for me. I often wonder if eM Client will ever see any more improvements/fixes, or if you guys have just given up.
BTW, I noted that someone on your side mentioned the num lock key, but that seems to play no part on my system.
Thanks for looking into it (maybe).
DGI
Hello David, I can assure you we’re working on new improvements and additions to the application each day. Unfortunately I’m unable to replicate any issues with the Ctrl+0 shortcut that allows the zoom level to reset to 100%, I’m afraid this issue might be related to an issue on your computer, as it is a standard windows shortcut. Please try to update your Internet Explorer to the latest release, if there’s possibly an update and make sure you have all system updated installed.
Also please check if you’re able to use the shortcut in Internet Explorer.
Hi: Thanks, perhaps it’s related to something on my system - it’s hard to know - but the Ctrl+0 return to 100% works for me in IE as well as Mozilla, Chrome, and elsewhere, even 20-year old Qualcomm Eudora. But not eM Client.
