With version 7 and 8 beta there is the problem that the contacts from emClient to Google contacts do not work. I get this error message and I don’t know what to do:
https://www.hoffmann-jahn.de/emclientsync.png
Thanks.
Walter
Thanks.
Walter
Can you please post your screenshots in the comment like this, rather than making a link to some other site. If the image is later removed from that site, then your post here becomes incomplete.
Are you using the same email address to login to this account (found in your settings in Menu > Tools > Accounts) as the address I have redacted in your screenshot?
Thanks a lot…how can i edit my post?
do you have a solution?
Thanks.
Don’t worry about the post as you can’t edit it after there has been a comment.
There was a similar issue on this forum where the user was using a different email address to sign into the account than the one listed in the error. Therefore I asked that question.
Yes, I use the same…
You could try removing the Google account from eM Client, then add it again.
Hi Gary,
i have done it and it works…thanks…
but now, there is another problem: the “refresh” runs ans runs and runs…
That may initially take some time as it will have to re-cache the All Mail folder.
but 12 ours and more???
Hi Gary,
i deleted 8 beta and i am back to 7.2.38732.0…
Thanks for your help.
Where are you? In USA? Then you have to sleep
Kind regards
Walter
Is it working OK in version 7?
I am in the UK.
Hi Gary,
version 7 works perfect for me: 1) only quick sync and 2) no problems with contacts from and to Google…
Thanks a lot for you help.
I like the UK and the UK-people…please look:
https://www.hoffmann-jahn.de/eine-seite/
Kind regards
Walter
