When I open a Contact Card - it comes up and is transparent - makes difficult to read - tried different Themes - same result.
Any ideas?
Close and uninstall eM Client, making sure NOT to delete the database folder when asked. That will ensure all your data and settings are there later.
If it exists, delete the C:\Program Files (x86)\eM Client folder.
Download and install the latest version from here: https://www.emclient.com/dist/latest/setup.msi
Restart eM Client.
Does that fix it?
Done a reinstall (kept Database) and still the same.
Also, though probably not related, emclient takes over 10 mins from cold boot to open - once started I can close and reopen in a reasonable time.
Are you using a custom theme? If so, go to Menu > Settings > Appearance > Themes and change to one of the themes that are provided by us. Click on Save & Close. Do you still have the same issue?
If it is not a theme, can you upgrade your graphics drivers then restart Windows and see if there is any difference.
martes 23 mayo 2023 :: 1009hrs (UTC +0100)
What OS and version of eMC are you using?
IMAP or POP?
Connection speed?
HDD or SSD?
skybat
¡Buena suerte!
¡Los mejores desde Valencia la soleada y mantente a salvo!
