I keep getting the following message when I open eM Client. Using version 8.2.1479.
[Google Contacts]Creating or updating folder ‘Rusty"s Email/Contacts/Coworkers’ failed due to the following error: Cannot modify a system group.
How do I get rid of this??
If you are using a Gmail (IMAP) account, i would suggest to remove your Gmail account and re-add which should then re-sync your Mail, Contacts and Calendar etc and that should fix it.
Note:- Backup eM Client first via "Menu / Backup.
Lastly if you have eM Client for Windows, there is now later versions available which have alot of bug fixes. So suggest to also update the program as well. https://www.emclient.com/release-history
