Sometimes it uncategorized some contacts and I lost some of its details
Everytime asked to “overwrite local” or “overwrite remote” I lost all details of that particular contact and left me only name, I lost dozen of 6 years contacts for that… tragic
P.S. I use “windows 7 64x”, “Google Apps” , and “windows mobile with m.google.com sync”
What version of eM Client do you use? We recommend to update to most recent version.
You can restore your contacts if you log to gmail by web, then go to your contacts and click to More->Restore contacts…
EM Client has some problem with its localization with Google, particular if you use Mobile Sync such as Nokia MFE using exchange protocol. Sync Google Contact to eM is not recommended at the moment if you are using mobile sync.
Earlier 3.5 would cause some serious issue with Google Contact, even if the contact service is disabled. Google’s exchange protocol itself is buggy as well this has being raised as an issue at Google Groups, that includes the immature SyncML. We need to wait for both side, though Google’s one would be tough, as the exchange issue has been there since 2 years ago.
