Constant error in syncing calendar and contacts
Over the past few weeks, my em client has started constantly telling me that it cannot sync calendar and contacts with the following messages:
[Google Contacts] Synchronizing folder ‘Chris Gmail/Other Contacts’ failed due to the following error: The request was canceled due to the configured HttpClient.Timeout of 100 seconds elapsing.
[Google Calendar] Synchronizing folder list failed due to the following error: The request was canceled due to the configured HttpClient.Timeout of 100 seconds elapsing.
What am I doing wrong?
Could be caused by a eg: background resident program possibly interfering delaying the client updating, or could be a local calendar cache issue that needs clearing, or could be a corruption in the account so won’t sync to the server anymore.
So first if you have any optionally installed firewall / security programs, or optionally installed antivirus programs, or vpns “other than what comes default with the os”, try completely disabling those to test incase of interference & see if that fixes it. Also if you have Windows try also resetting the windows firewall to defaults incase thats been modified.
Next if you have no optionally installed programs like the above or you do but disabling makes no difference, then next “right click on the word “Calendar” directly under your Gmail address in the Calendar section, and click “Properties” at the bottom. Then click the “Repair” tab at the top and finally click “Repair” and see if that fixes it.
“Repair Google Calendar example thread post”
If repairing the Calendar cache still doesn’t fix it, then suggest next to go to “Menu / Accounts” and remove and readd the account via the automatic account wizard along the top which should fix it.
Note: If you do remove and readd the account, before removing make a backup first via “Menu / Backup” incase you need to restore for any reason.
Thanks. Eventually, deleting and readdibng accounts fixed it.
Sadly, this emerged again so did your fix. This again worked for a few days. I have now found that, if I change my network settings from private to public, this solves it. Sadly, this disabled file sharing. Is there a way round this?
What network settings are you changing ?
We have two computers running win12 connected by ethernet in a network for file and print sharing. Under settings, network, ethernet you can switch between public (recommended) or private. We have used latter to permit file sharing. If I switch to public, the email problems disappear. This is not just em. I tried mailbird and same issue and same solution.
That can happen if a local firewall is active. So make sure you have allowed eM Client in the Windows Firewall Defender and allowed eM Client in any Third Party Firewall / Security program.
Apart from that you might need to eg: Flush your DNS.
