connection problems
I signed up, set up as per instruction, it will not work.
Hi George, can you please a little bit more specific with your issue description?
What version of eM Client are you currently using? Are you seeing any errors from the application? If so, can you make a screenshot of the error?
What mail service are you using with eM Client?
