I have setup my Gmail (with my own domain) in this client. But sending e-mail is not possible. I already tried tools -> accounts -> diagnostics and fix all.
The settings are gived by Gmail. What’s wrong?
if the problem is still actual, try to re-create the account and let me know if it helps.
If you use Avast!, I know that it has Mail Shield. Try disabling that, that is what helped me!
I have tried to re create the e-mail account several times but the same problem occurs.
I have Mc Afee Enterprise 8.8 installed.
Thnx
Send us your logs please: go to menu Tools->Settings->Advanced->Logging and check “SMTP” under the problematic account. Then restart eM Client, try to simulate the issue and send us (with reference to this topic) the logs using the same logging settings window. Thank you.
Hi George,
Thank you for your reply. To make sure that my privacy is not on the internet I replaced my 2 e-mail adresses. Further I nothing changed in my log. Thanks
12:20:30 Online toestand: gewijzigd in online met als reden NetworkAvailability
12:20:31 teun@…com [IMAP] Synchronizing subfolders: For folder teun@…com/
12:20:31 teun@…com [GData] Synchronizing folder list
12:20:31 teun2@…com [IMAP] Synchronizing subfolders: For folder teun2@…com/
12:20:31 teun2@…com [GData] Synchronizing folder list
12:20:31 teun2@…com [GData] Synchronizing folder ‘teun2@…com/Contacts/’
12:20:31 teun@…com [GData] Synchronizing folder ‘teun@…com/Contacts/’
12:20:32 teun@…com [GData] Synchronizing folder list
12:20:32 teun2@…com [GData] Synchronizing folder list
12:20:32 teun@…com [IMAP] Synchronizing subfolders: Done
12:20:32 teun@…com [IMAP] Synchronizing subfolders: For folder teun@…com/Inbox
12:20:32 teun2@…com [IMAP] Synchronizing subfolders: Done
12:20:32 teun2@…com [IMAP] Synchronizing subfolders: For folder teun2@…com/Inbox
12:20:32 teun2@…com [GData] Synchronizing folder ‘teun2@…com/teun2@…com/’
12:20:32 teun@…com [IMAP] Synchronizing subfolders: For folder teun@…com/Bleek
12:20:33 teun2@…com [IMAP] Synchronizing subfolders: Done
12:20:33 teun2@…com [IMAP] Synchronizing subfolders: For folder teun2@…com/[Gmail]
12:20:33 teun@…com [GData] Synchronizing folder ‘teun@…com/Nederlandse feestdagen/’
12:20:33 teun@…com [IMAP] Synchronizing subfolders: Done
12:20:33 teun@…com [IMAP] Synchronizing subfolders: For folder teun@…com/Prive
12:20:33 teun@…com [GData] Synchronizing folder ‘teun@…com/Stefan/’
12:20:33 teun@…com [GData] Synchronizing folder ‘teun@…com/teun/’
12:20:33 teun2@…com [IMAP] Synchronizing messages: For folder teun2@…com/Inbox
12:20:33 teun@…com [IMAP] Synchronizing subfolders: For folder teun@…com/[Gmail]
12:20:33 teun@…com [GData] Synchronizing folder ‘teun@…com/teun@…com/’
12:20:33 teun@…com [IMAP] Synchronizing messages: For folder teun@…com/Inbox
12:20:34 teun2@…com [IMAP] Synchronizing messages: Done
12:20:35 teun@…com [IMAP] Synchronizing messages: Done
12:20:52 teun2@…com [XMPP] MailExceptions.ConnectionException:
12:20:52 (Een verbindingspoging is mislukt omdat de verbonden party niet correct heeft geantwoord na een bepaalde tijd, of de gemaakte verbinding is mislukt omdat de verbonden host niet heeft geantwoord 173.194.70.125:5223)
12:20:52 teun@…com [XMPP] MailExceptions.ConnectionException:
Try to disable your Firewall/Anti-virus for a while and let me know if it helped. This issue is caused by something blocking your connection.
Hi George,
I have disabled my AV and my Windows Firewall but this will not solve the problem. With my MS Outlook client I do not have this connection problems.
What do you suggest to try now?
Thanks!
If you are able to simulate the issue, contact me directly at [email protected] - I will send you further instructions.
