Upgraded yesterday to version 9.2.2093.
Every 10 minutes email disconnects from server and reconnects 10 minutes later.
Has anyone else had this?
See anything in the MENU > OPERATIONS > LOG that might give a clue as to the problem?
Running a VPN? If so try turning it off or changing to a different server.
Have you checked with your Host Server to so if they are having any issues?
Hello sunriseal. I reset the router and it has sorted the problem, thanks for your help.
