I am getting a connection error, it was working and now it isn’t. Any idea how I can fix it?
Can you give the error which you will find in Menu > Tools > Operations > Log tab.
Please see examples of the error messages
09:18:21 MailClient.Accounts.AbortedException: Authentication aborted by user.
09:18:21 at MailClient.Protocols.CalDav.ProtocolCommands.Connector.RunCommand(CalDavAccount account, ICommand command, CancellationToken cancellationToken)
09:18:21 at MailClient.Protocols.CalDav.Synchronizer.BootstrapCommand.UpdatePrincipalProperties(Uri baseUri, Boolean retryOnNotFound)
09:18:21 at MailClient.Protocols.CalDav.Synchronizer.BootstrapCommand.Execute(WorkerStatus status)
09:18:21 at MailClient.Commands.Command.Process(WorkerStatus status)
Is the error only with the CalDAV?
Did you try removing the account, and adding it again?
I receives, but it doesn’t send. I have included a screenshot
OK, that has nothing to do with CalDAV.
Go to Menu > Tools > Accounts and click on the SMTP tab. Make sure that the port is set to 587 and the security policy is set to Force usage of SSL/TLS.
If that still does not work, temporarily disable your anti-virus/firewall application, then try again.
It still doesn’t work. I will try the firewall.
It usually sends eventually, it just takes a long time.
I havent been able to send or receive since Sunday. I have tried all of the normal things, modem and router reset, turn pc off and modem reset, ran malware and virus scans etc. Need help. Below is a copy of error messages. It has worked flawlessly until Sunday.
11:33:55 PM at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)
11:33:55 PM at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
11:33:55 PM at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
11:33:55 PM at System.Net.Security.SslStream.AuthenticateAsClient(String targetHost, X509CertificateCollection clientCertificates, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation)
11:33:55 PM at MailClient.Protocols.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
11:33:55 PM — End of inner exception stack trace —
11:33:55 PM at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
11:33:55 PM at MailClient.Commands.Command.Process(WorkerStatus status)
11:33:55 PM [email protected] [POP3] Connected: To [email protected]
11:33:57 PM [email protected] [POP3] Downloading messages: From [email protected]
11:33:57 PM [email protected] [POP3] Disconnected: From [email protected]
11:33:57 PM [email protected] [POP3] Disconnected: Done
