usabilidad pantalla tactil
Hi Antonio, not completely sure if I understand, can you please maybe specify the question a bit? If you’re using a touch capable device, you should be able to activate the touch mode by using the touch mode button in the application header.
Paul
hello paul: I need is to do multiple choice post through the touch screen for batch processing, such as multiple file selection through boxes element having windows 8.1 for this interface
Hi, if you’re using touch input, you should be able to select multiple items by swiping to a side in the item list, however this feature is only available for the list of received messages.
Paul
