Hallo, ich verwende noch den Client 7.
Jetzt ist er mir total abgestürzt. Meine Sicherung ist aber 6 Wochen her.
Vor der Wiederherstellung der Sicherung habe ich noch den kompletten Ordner gesichert.
Nun meine Frage, es fehlen mir jetzt wichtige e mails, kann ich diese seperat wiederherstellen?
Dazu müsste ich wissen wo in der Datenbank die einzelnen e mails gesichert werden.
Könnte mir da jemand helfen? Das wäre toll.
Gruß Pirol
Hello, I’m still using Client 7.
Now it’s crashed completely. But my backup was 6 weeks ago.
Before restoring the backup, I backed up the entire folder.
Now my question is, I’m missing important emails, can I restore them separately?
To do that, I would need to know where in the database the individual emails are backed up.
If you are currently using eM Client V7 and have an eM Client V7 (backup.zip) file in your “Documents / eM Client” folder, or have a copy of the eM Client V7 (hidden database folder) from 6 weeks ago, you can do a partial restore.
(How to do a partial restore from a backup)
1). If you have been making regular eM Client V7 backups and have an eM Client backup zip file in your “Documents / eM Client” folder with the messages you need, then “Close eM Client” and then go to the following eM Client Pc or Mac database folder location and rename the folder to eg: eM Client-Current.
(Hidden database folder Mac)
/Users/User Name/Library/Application Support/eM Client
2). Then “disconnect from the Internet / go offline” and then open eM Client and skip the setup account wizard. Then restore your V7 backup.zip file via “Menu / File / Restore”.
3). Next you need to export your messages you need either via using “Menu / File / Export” or by Creating a folder on your desktop called eg: eM Client-Old , and then dragging / moving any messages and/or any custom message folders you do want to the eM Client-Old desktop folder.
4). Then once you have all the messages out of eM Client, then close eM Client and “delete the new eM Client hidden database folder”. Then rename your original eM Client-Current database folder back to eM Client. Then reopen eM Client.
5). Next import your messages that you either exported / saved via “Menu / File / Import”, or by dragging the messages & message folders back from the eM Client-Old desktop folder into eM Client. Then lastly reconnect to the Internet.
Now “if you haven’t been making regular eM Client V7 backups” and “have no Backup.zip file” in your Documents / eM Client folder, “but do have your eM Client V7 hidden database folder location backed up”, then do the following.
1). Close eM Client and then go to your current hidden database folder location and rename it to eM Client-Current.
2). Then copy your backed up eM Client V7 hidden database folder “to the same hidden database folder location” and then “disconnect from the Internet / go offline”.
3). Then open eM Client which should then be the same as it was before with all the missing messages.
4). Next you need to export your messages you need either via using “Menu / File / Export” or by Creating a folder on your desktop called eg: eM Client-Old, and then dragging / moving any messages and/or any custom message folders you do want to the eM Client-Old desktop folder.
5). Then once you have all the messages out of eM Client, then close eM Client and delete the new eM Client hidden database folder. Then rename your original eM Client-Current database folder back to eM Client. Then reopen eM Client.
6). Next “import your old messages” that you either exported / saved via “Menu / File / Import”, or by dragging the messages & message folders back from the eM Client-Old desktop folder to eM Client. Then lastly reconnect to the Internet.
Danke, das hat mir sehr geholfen.
Gruß Pirol
