Client randomly crashes
After updating a few days ago to 10.4.5674 (fcbf2a4) the software randomly crashes while not being actively used. I have been using eM client for a few years and this problem only started since the most recent update. Works fine otherwise.
Could be possibly the update didn’t completely install correctly 100% or something else might be interfering with the mail client when inactive or could be you might need an OS update or could be a problem with your actual database.
So first make a manual backup via “Menu / Backup”.incase you need to restore which by default goes in your “Documents / eM Client” folder location. You can see when that’s completed in Show Operations via in the dropdown on the right of Refresh.
Then uninstall eM Client and if you have Windows “don’t delete the database” when asked on the uninstall wizard.
Then redownload and reinstall V10.4.5674 again
for Pc or Mac either from the release history page or Windows store depending on where you got the update from. Then after reinstalling “shutdown & reboot your computer” and see if that fixes it.
If uninstalling and reinstalling doesn’t make any difference then “check you have done all your OS updates” as there has been a lot of new OS updates recently, and that your running either Win 10 or 11 or one of the last 3 Mac OS,s incase you have an outdated OS that might need updating.
Apart from that if you have any eg: Power management enabled to set drives to sleep try disable that to see if it makes any difference.
Also if you have any eg: optionally installed firewall / security programs or optionally installed antivirus programs or vpns running “other than what comes default with your os” try completely disabling those to test incase of interference.
Also if you haven’t already tried, “shutdown and reboot your computer” just incase it’s some other unknown resident program causing the crash.
Now if rebooting you computer makes no difference and you have no optionally installed programs like the above installed or you do but disabling those makes no difference, then “it could possibly be your current database” and you might need a new one to test if that’s the issue.
So I would next suggest to test if its a database issue, first if you have a POP account or Messages in local folders, go to “Menu / File / Export” and export any messages, contacts, tasks, notes to a folder on your desktop to then reimport later after reinstall.
Then “close eM Client” and go to the following hidden database folder and rename it to eg: eM Client-Old .
(Hidden database folder Mac)
/Users/User Name/Library/Application Support/eM Client
Then “reopen eM Client” and setup as new. If you have an IMAP, Exchange, Office 365 or iCloud account, all your messages, etc will come back from the server once setup and see if that fixes it.
If you did have a POP account or Messages in Local folders, then after resetting up as new, go to “Menu / File / Import” and reimport all your messages, contacts, tasks, notes from your desktop folder you exported to previously.
Alternatively “if you did either a manual eM Client backup “prior to updating” or have an automatic recent backup of eM Client “prior to updating” when it was working ok, then you could try restoring that instead via “Menu / File / Restore” and see if that fixes it. Any emails etc since the backup will then update when eM Client reconnects to the server.
Thank you. I will look into these suggestions.
