Since the 1st of January everything in Gmail calander is change to GMT and not to GMT + 10 which is what my pc is set to… if I can an event before 2014 it is fine but anything after it loses the gmt+10 I have 6.0.19714
Ok if you change on gmail webpage or android app it keeps the right time but if you change it on emclient or create it on emclient it posts it as GMT
Hi, thank you for this exact explanation, we have tested your scenario and it is happening exactly as you have described.
Your explanation helped us narrow possible issue core so we should be able to repair this soon as possible.
with regards
Jan
