I downloaded eM Client 6.0.20025.0
It does not connect to Exchange.
In the automatric configuration is it says “server found authentication failed.”
My credentials are correct.
when I try to configure under Other (either in POP3 or IMAP) the Ourgoing server tests correctly (proving credential are OK) but Incoming Server test fails.
(It could be that POP3/IMAP fails becasue of no authorization for POP3/IMAP on Exchange side. I will look into that, but I want eM to connect to Exchange properly not via PO3/IMAP.
Any leads how to fix this (I see several user complaining about eM not working properly with Exchange. Is this a known issue?)
Second, when automatic configuaration of Exchange works, it is a proper push connection or does eM connect to Exchange as POP3/IMAP regrdless if configures automatically or as Other?
