Hi
I want the message pane to behave as it does in Microsoft Mail. That is:
I click on a message in the list of messages and this opens in the message pane.
I click on the message entry again and it clears it from the message pane (leaving the pane blank).
When I move a message that I am reading (i.e. it is open in the message pane) to a folder, it clears it from the message pane but eM Client does NOT go to the next message and open it - no message is selected and the message pane remains blank.
The same behaviour when I delete a message - do NOT open another message.
It’s a shame that eM is not flexible enough to allow the behaviour I am after because of the way that the ‘next message’ and ‘mark as read’ settings work.
If, after reading a message I either move it to a folder or delete it, then eM will automatically open the next message. If this is an unread message then it will automatically be marked as ‘Read’ after x seconds, whether I have actually read it or not.
(I am aware that I can set the number of seconds, but setting it to a very high number has its own disadvantages.)
Looks like my search for the ideal email client continues…!
If you (enable) the option “Mark messages read after opening in separate window” and (disable) the option to “Mark messages read after displaying for x seconds”, then no emails will automatically get read “unless you dbl-click to open the emails” and won’t automatically mark read on the next message.
