Hello everyone,
Greetings from Brazil! Here’s the deal: I love eM Client, but simply hate its icon. There’s something about it that annoys the heck out of me… Anyway, I already changed the application icon on the Windows 10 Task Bar, but can’t figure out a way to change the icon in the System Tray. Does anyone know how to do this? Thanks a million! I really appreciate your time and help.
Best regards,
JC.
Not a good idea to tamper with an app dll’s in order to change icons like the one in the system tray. I used to use a small app to customisze anything graphical in the Windows OS environement, including system tray icons. Try your luck here.
Thank you very much for your reply. I had already tried that app, but to no avail… If I knew exactly what dll file holds the eM Client app System Tray icon, I would edit it and change it using Resource Hacker.
