i change DB location and lost every email. how i recover them? hurry please support me.
they should be in their previous location you have had set (it is C:\Users\YourUsername\AppData\Roaming\eM Client or C:\Document and Settings\YourUsername\Application Data\eM Client on default) so you need to set the location back to it.
try but fail. do u have another solution?
Did you use IMAP or POP3?
If they were IMAP emails, they should be on server - try to recreate your account again whether eM Client will download them from it.
If they were local (POP3) they are not at the server after some time - try to find your database files (e.g. file named “main.dat”). If you cannot find them try to use some undelete utility for your disk. You can also try to recreate the account to check whether they are not still at server.
ok thanks i’ll try
sorry not works
