Certificat du site Web révoqué
Le [certificate](data:application/pkix-utilisé par ce serveur a été marqué comme n’étant pas digne de confiance. La connexion n’est pas sûre.
Cette erreur a été causée par une réponse OCSP non valide. La réponse doit être valide, car l’agrafage OCSP est utilisée.
Veuillez contacter les propriétaires du site web pour les informer de ce problème ou essayez de vous reconnecter ultérieurement ou à partir d’une autre connexion Internet.
L’accès à la page Web a été bloqué.
website certificate revoked
The [certificate](data:application/pkix-used by this server has been marked as untrusted. The connection is not trusted.
This error was caused by an invalid OCSP response. The response must be valid because OCSP stapling is used.
Please contact the website owners to let them know about this issue, or try logging in again later or from a different internet connection.
Access to the web page has been blocked.
When do you see this error ?. Is this when eM Client checks email and is an error from the Operations / Log tab as you are not getting any email in your inbox ?, or do you see this error in your inbox as a bounced back / rejected email ?.
Also what version of eM Client are you running and do you have Windows or Mac.
Sometimes this error can also be caused by eg: If your Windows or Mac OS time and date and timezone is wrong. So dbl-check those are all correctly set in your OS.
