I found the em client few days ago, and it looks like a great email client. Before I will buy some pro licenses I test the software with the free license.
So my problem is that the emclient sync only 10contacts from the egroupware addressbook. I have 4700contacts on eGroupware.
Hi Lukas, no this is not a limit of the application, you should be able to synchronize your account completely, using the free version you can use a maximum number of two accounts, you should be able to synchronize both completely with the application.
What version of eM Client do you have currently installed on your computer, can you please check the exact release number in Help > About? Are you seeing any errors thrown by the application when you try to synchronize your account?
