I would like to purchase the full version but I need it to work with CardDAV and CalDAV with nextcloud. I tried several configurations but no one works for me.
I donât use AV software. eM Client is able to connect to nextcloud but not to login. The error message is âUnauthorisedâ and the sync error log says âMethod Not Allowedâ.
On my nextcloud I switched of the âBrute-force settingsâ app and other security apps.
Please can you tell me how to set the right entries.
Account name:
Name:
Username: (Just the username or âUstername @ Urlâ
Password: (I believe it is just the password nothing else)
Server Address:
(my nextcloud installation is not in an subdirectory and I get the following URLâs from my nextcloud calendar)
https:// and
xxxxxx. net/remote.php/dav or
xxxxxx. net/remote.php/dav/principals/users/(username)/ or
xxxxxx. net/remote.php/dav/addressbooks/users/(username)/(name of addressbook)/
I separate the links because your chat system donât like so many links.
When I add the the server URL without remote.php/dav/ or URL with remote.php/dav/
I receive no password false message and the following log messages:
22.08.2020 09:53:28
xxxxxxx CalDAV / CardDAV Account properties are synchronized: For host https ://xxxxxxxx. net/
22.08.2020 09:53:36
xxxxxxx CalDAV / CardDAV Account properties are synchronized: Done
22.08.2020 09:53:36
xxxxxxx CalDAV / CardDAV Sync subfolders: For folder xxxxxx
22.08.2020 09:53:38
xxxxxxx [CalDAV / CardDAV] MailClient.Storage.Application.OperationException: The subfolders of the âxxxxxxxâ folder could not be synchronized due to the following error: Method Not Allowed
For everyone who has the same problem with Nextcloud.
Usually you try to install and configure Nextcloud as securely as possible. But then it doesnât work with eM Client. The eM Client query is simply not allowed.
Here is the solution:
You just have to add an app authorization to the Nextclud installation. You do this as the admin under âSettingsâ with the menu item âSecurityâ. Here is a list of queries from apps below. There you will find your mobile phone, computer and other apps that have access.
Below is an input field (app name) and here you simply enter âemClientâ. Now click on âCreate new app passwordâ and then add this password to your eM Client in the Nextcloud CardDAV / CalDAV account.
