They have a problem and they are not acknowledging it. Shame will unistall
Hi Christine,
Please don’t give up … maybe the latest version of eM Client will help you?
the latest version is the problem
Hi Christine,
You mentioned above that you’re using version 6.0.21040.0 … that’s not the latest version … I’ve posted a link to version 6.0.21151, which is newer than the version you’ve mentioned.
Maybe you can give that version a try?
I never got the link
Hi Christine, sorry for my late reply, if you’re still having issues with this, can you please try to add eM Client on the list of exceptions in your avast settings and check if the issue persists?
Paul
Hi Quartzy,
If you look 4 posts higher, you will see the link to version 6.0.21151 of eM Client which I’ve posted here.
However, there’s already a newer version of eM Client available:
