A few days ago my work enabled and required MFA (Multi Factor Authentication) using AIM (Azure Identity Manager) services. I have deleted and tried re-adding my Office 365 email account back into eMClient, but it fails. I don’t get any type of prompt for the MFA portion. I have tried both automatic and manual setup with the same result. I am on version 8 of eMClient.
Any direction would be appreciated since I can no longer get my work email through emClient.
FWIW, I also use MailBird, and had no issue setting my work account back up with MFA in MailBird.
I will also add that AIM MFA does not allow the use of an ‘app password’ like the base O365 MultiFactor, so using an app password is not an option. I need to actually get the MFA promp to appear like I do in Outlook or MailBird.
This solution worked for me! Thank you SO much for providing this info. I have followed the simple steps and confirmed Microsoft MFA via Azure is working and allowing me access to my work email again.
emclient does not work for me with office365. I have installed the registry keys. The automatic setup does not work. “The correct settings could not be determined”
When I try manually I have no luck either.
Thanks for your help
Manuell,
ich wähle Exchange aus
Server https://outlook.office.com/
xxx[Exchange Web Services] MailClient.Accounts.ConnectionException: Couldn’t get server version.
MailClient.Accounts.ConnectionException: Invalid host or path address.
What happens if you remove the Exchange account from eM Client, then go to Menu > File > Import > Microsoft Outlook, and import the account from your Outlook settings?
I don’t know what to suggest except that if you have tried everything, including the app password and not the account password, then if you have a Pro License, open a support ticket with eM Client.
