Can;t read files after system crash
My sytem crashed and I only could recover a small number of files. I wonder if somebody knows a way to read the content of those files.
I recovered the following em client files:
attachement
catagory_index
certificate_index
contact_data
contact_index
event_data
event_index
folders
im-data
mail_data
mail_fti
main
manifest|
privacy-list
security_index
settings
task-data
task_index
telemetry
timezones
I could not find a program to read those files, who can help me out ?
Hi Sierd,
Normally eM Client will do a database check when you start eM Client and it has detected that it was not closed correctly previous time.
Is eM Client doing this database check?
If eM Client is successfully started, do you see that items (contacts, e-mail, appointments) are indeed missing?
Which version of eM Client are you using?
Hi, are you using IMAP or a POP email account(s)? unfortunately eM Client’s database uses multiple database files to store it’s data and if you were only able to save this small number of database files from the database directory, there’s not much to save. However you should be able to open the .dat files in a text editor, for example mail_data.dat should contain some of your emails, however they are not in a format you would be able easily transfer back to the application or anywhere else.
It’s always recommended to keep a backup of your database.
