CAN NOT SEND EMAILS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I loved eM client, until yesterday. For no reason it stopped sending emails.
Have google to see try to get an answer looked here. If the answer is here
I’m not techy enough to find it.
Have it so screwed now will probably call my server tech support, then
go back to thunder trud.
can I ask what version exactly do you use, and what email service provider do you use?
Jan
Thanks for the reply, if any part of my computer is down more than 30 seconds I go
into a emergency fixit campaign. I called Century Link support, some how my port
numbers had changed. Don’t know what that was all about but now I WORKS!!!
Thank you for update on your issue.
Jan
