the program brings the error message and does not start. I had the data on the server, which is due to a defect for repair. In which file can I change the path so that I have access again?
Best regards -
Andreas Hickmann
eM Client does not play so well when a network location or external disk is not available. On a local disk, if the folder is not there the application simply creates a new one. So you will need to change the path in the registry. You can find the setting in Computer\HKEY_CURRENT_USER\Software\eM Client. Change the DBLocation key.
Thank you for your help.
