I am using emClient 6.0.24928.0. I am trying to sync with my Telus.net account; mail is perfect but calendar does not update in either direction.
Can you please try turning off your antivirus and firewall to see if that helps?
Dave
Hi - that didn’t work but thanx for the help anyway. I eventually had to set my calendars on my phone and tablet to GMail calendar; then add JUST the calendar to emClient. I am now updating across all 3 devices. It would have been a lot easier though if I could have used everything from my Telus account. This has now been solved. Thanks to all.
