I have 4 calendars, all selected (checked). Periodically, they randomly deselect (uncheck) themselves so when I view my calendar page my appointments are not visible until I reselect the missing calendar.
Any clues how to stop this happening, please?
Hi, when does this issue occur? Do you switch between tabs/windows etc. The selected calendars should only change when you click on other folder to select it - others are then deselected.
What version of eM Client are you using?
v 6.0.20154.0
Not quite sure I understand your scenario. Surely selected calendars should change only when selected or deselected? Mine have been deselected without me clicking on the little coloured section box. It’s only occurred over the past day or two, as far as I can tell, and only when I’ve left the calendar tab and returned.
Hi again, can you try updating to this version of our application and let me know if that issue occurs again?
(http://www.emclient.com/dist/v6.0.20320/setup.msi)
Just went to calender and only 1 is checked.
Just refreshed calendar and 1 calendar (my main one) unchecked itself.
This seemed to cure itself for a while, after updating to 6.0.20320, but has started to recur in the past day or two.
