Hi, with the new version of eM Client (5.0.17211.0) I’ve some problems in Calendar tab. When I try to change the calendar color the program return an error
MailExceptions.OperationException: Creazione o aggiornamento della cartella ‘[email protected]/xxx@yyy/’ fallito con un errore: Object reference not set to an instance of an object. —> System.NullReferenceException: Object reference not set to an instance of an object.
So, also when I try to repair a calendar I get the same error message.
Thank you in advance.
Nicola
