calendar not imported from emclient 6 to 7
I just installed version 7. Mails and contacts were imported but not the calendar events. I still have the old files.
What can I do ?
Thanks
I would also like an answer to this as i have had the same problem.
I have managed to install emclient 6 on a vmware virtual machine and put all the flies in the data folder into the data folder on the virtual machine. Then I exported the calendars (4) in seperate files. I moved the exported files back to my computer and imported the calendars into the new emclient.
It’s only a work around if you know how to create a virtual machine.
That’s a stupid bug ! This should have been tested before the v7 release !
Me too. Tasks didn’t import either.
