Looking at buying the pro version but having some issues with the calendar. I’m selecting the right calendar (ie the google apps account email) but there seems to be some issues:
Calendar entries added by me which then disappear when I tried changing the time
Inviting others to meeting and the invite not being received and then disappearing.
Hi Julia, not completely sure what you’re referring to, what version of eM Client are you currently using on your computer, can you please check the exact release number in Help > About? Are you able to replicate this issue with each occurrence/event that you add to the calendar?
Are you using any security software on your computer, that may have partially disabled the synchronization capabilities of the application with your calendar service?
