You should be able to set the default reminder setting on the calendar for all new events. That way you wouldn’t have to manually edit every calender event to set a reminder.
I agree. Please make this possible ASAP! It’s very frustrating when you add a new event and forget to set the reminder for each one, and a whole day goes by and you have neglected all of your events!
This should definitely be a priority update!
Definitely need a default reminder!
Agreed - this missing functionality is quite dangerous!
a drop-down box in the settings/calendar dialogue is all that we need
(great suite, btw!)
When will this be implemented?
Definitely need to set a default reminder for all new events!
Another +1 for this feature!
We plan to implement it in one of the eM Client 5 updates.
Add my vote to the addition of a calendar default reminder please.
Any update on when we will see this?
Most probably it will be present in the version 5.5 which should be released in a few months.
Could this be extended to include the default privacy setting.
I agree - it’s tedious to set each time, and easy to forget.
So glad to see this is in progress! Kudos!
Please add this feature!!!
Plus 1 here. Please add functionality to set default reminder times.
Hi - any update on this?
It should be implemented in the upcoming version 6 which will be released in 2-3 months.
and please also coincide with a default length of the new appointment. In addition, the Reminder icon ALWAYS has to be appear in front so can you tell if a reminder has been set.
Ok, we will consider it!
Any update on when this is going to be released?
