I have set up a CalDAV calendar for a while now, and it works very well, except a small issue. Small, but annoying:
For whatever reason, the default color assigned par eM Client to this calendar is pink,
then I change it to purple (using the LHS calendar treeview, and right-click, then “Calendar color”
After some time, or some event, it ends up to be reverted to pink
I checked that “Refresh” was not the culprit: if I do a full refresh, my calendar color is not reset, but it will some (undefined) time later
Could you have a look at this one please?
I have the same issue here. I ́m using Open-Xchange and do have two calenders. One of mine and a shared one. They have both the same color in em Client and it isn ́t possible to change it permanent.
Any feedback on this one? As a developer myself, I guess that shouldn’t be a big issue to fix (though I may be wrong as not knowing the code…).
Anyway, that would be nice to have at least a comment on this from you guys, thanks in advance!
Cheers,
Jean-Marc
In our company, we are using a CalDAV-Server (don’t know which type of) and that one delivers the calendar information of each of my colleague. At the CalDAV-Server is stored which color the calendar of my colleague has. And this information (I guess) is read by em Client.
If I change the color of one of my colleague’s calendars, the em Client tries to persist this information at the CalDAV-Server (which, I guess, is the bug/mistake). But: the color information is read only for me! So this information is not persisted.
So please: add a feature to store the color of a (CalDAV) calendar in the local profile.
One side note: I wrote about this issue 4 or 5 years ago to the em Client support via e-mail. They asked me to open a “feature request” at the forums. I guess no one of the support team has ever read this post here. Really sad!
