My calendar appointments are all out by one hour compared to when I look at it in Gmail. In Gmail Calendar it is correct, in EM Client it is out by one hour (ahead). I am in Perth (GMT8) and there is no daylight savings…
Hi, what version of eM Client are you currently using?
The latest one, then one from the link you provided above.
Hi, what link? Can you tell me the number version from Help > About?
6.0.20154.0
Hi Alexi,
Based on other messages in this forum, I guess that new appointments should be okay, and that only your current (or old) appointments might be off by 1 hour.
You can solve that by doing a ‘repair’ of the calendar.
Select the calendar in the left column
click on it with your right mouse button
select ‘properties’
select ‘repair’ tab page
click [repair]
I did that and same issue…
Can you please make a screenshot of the issue? And maybe export one of the appointments/events and send it to my email ([email protected])?
