Everytime I go into my calendar it crashes.
Here is error message code. Would appreciate any help you can provide so I can use this application.:
Error msg code: eM Client (6.0.24316.0)
Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.34209
System.ArgumentOutOfRangeException: Year, Month, and Day parameters describe an un-representable DateTime.
at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
at System.DateTime…ctor(Int32 year, Int32 month, Int32 day)
at MailClient.UI.Controls.Calendar.MonthCalendarView.refreshScrollbarPosition()
at MailClient.UI.Controls.Calendar.MonthCalendarView.ViewActivate(Boolean refreshvisibledays)
at MailClient.UI.Controls.Calendar.CalendarView.controlCalendar_ViewTypeChanged(Boolean refreshvisibledays)
at MailClient.UI.Controls.controlCalendar.DelegateViewTypeChanged.Invoke(Boolean refreshvisibledays)
at MailClient.UI.Controls.controlCalendar.set_ActualViewType(ViewType value)
at MailClient.UI.Forms.formMain.ActivateEventView()
at MailClient.UI.Forms.formMain.ResetFilter()
at MailClient.UI.Forms.formMain.ActivateToolStripConfiguration(String configuration)
at MailClient.UI.Forms.formMain.ActivateEventLayout()
at MailClient.UI.Forms.formMain.RefreshEventLayout()
at MailClient.UI.Forms.formMain.ActivateEventFolders(Boolean expandBox, Boolean ensureFolderSelected)
at MailClient.UI.Forms.formMain.leftSpine1_BoxActivated(Object sender, EventArgs e)
at MailClient.UI.Controls.ControlSidebar.ControlSidebar.OnBoxActivated(ControlSidebarBox box, EventArgs e)
at MailClient.UI.Controls.ControlSidebar.ControlSidebar.box_Activated(Object sender, EventArgs e)
at MailClient.UI.Controls.ControlSidebar.ControlSidebarBox.Activate()
at MailClient.UI.Controls.ControlSidebar.ControlSidebarBox.Maximize()
at MailClient.UI.Controls.ControlSidebar.ControlSidebarBox.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at MailClient.Program.b__4()
at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action`1 handler)
http://emclient.com/ns/report">;
eM Client
6.0.24316.0
false
4.0.30319.34209
