I am encountering an issue with my setup. Some but not all, of my eM Client installs are failing to connect Contacts and Calendars with the same settings as other that are successful.
There are no Errors reported, just an operation that never completes.
The Operations tab indicates the following:
[accountname]: Synchronizing subfolders
[CalDAV / CardDAV] For folder [accountname]/public/
The server is an Apple OSX 10.8.4 running Apple’s Server App.
The sync never times out nor finishes and as a result, no contacts or calendars are available.
I am configuring all CalDAV / CardDav accounts exactly the same
https://[domain]:8843/addresbooks/ where [domain] is my full DNS record for my server (example: server.xxx.com).
What ever it is, seems to follow some setting on the computer as I have tried to configure a user that works perfectly on a different PC and ended up in the same limbo. All PC’s are the same make and same configuration.
Any ideas how I can get these PC’s working?
