Bugs with em 7
Upgraded to em 7. Syncing with Gmail and old deleted emails appears. Trying to delete nothing happen and the numbers keep increasing when trying reload the app.
Hello Syam,
We’re sorry for the inconvenience. Could you please try the following steps?
  • Turn Conversations off (Menu -> View -> Conversations -> Disable Conversations)
  • Turn eM Client off
  • Go to eM Client’s installation folder (something like C:\Program Files (x86)\eM Client) and run DbRepair.exe (not the DbRepair.exe.config). Wait until the database check is completed.
  • Turn eM Client on
    Maurice
Thank you. The method worked!
